700 twin
Old Apr 24, 2016 | 07:08 AM
blackwolf's Avatar
Default 700 twin
I had the ignition upgrade done to my bike, everything seems to work alright except stator is flashing for a code on the pod anyone know how to clear this. or do I have more issues going on.
Old Apr 24, 2016 | 10:21 AM
Check that it's charging at least 14 volts at the battery at an idle. Plus load test the battery to make sure it can accept the charge. If these areas are good,disconnect the battery for 30 seconds and see if flashing is removed from speedo.Plus what's the code/flashing show?
Old Apr 24, 2016 | 12:50 PM
blackwolf's Avatar
Hi opt.... E checks out when the bike is idleing nothing shows, within a minute of driving the wrench symbol starts flashing and it starts flashing what looks like SEAE, I turned the service interval off, I disconnected the negative on the battery for 30 seconds, as soon as I drive it the wrench and seae starts flashing.Other then that the bike works great.
Old Apr 24, 2016 | 04:23 PM
If the wrench is still flashing I'd recheck to see if you turned the service wrench off. I've never seen this code come up on the older displays. If it was working ok before you installed the updated ignition kit,then I'd recheck the wiring.Entirely possible the speedo picked this point in time to crap out like this also.Several good posts on tearing into one if you have the time,ambition and ability to tackle this if it comes down to it.KA7OEI's blog: Repair of the speedometer on a Polaris Sportsman 500 4-wheeler Plus one from forum member TaterTots. AWD and Speedometer don't work - Page 2 - ATVConnection.com ATV Enthusiast Community
Old Apr 24, 2016 | 05:38 PM
blackwolf's Avatar
Just checked the service is off. I will check the wiring. thank you
fossilhunter35
Jul 25, 2016 08:58 AM
AC-Greeny
May 8, 2016 04:03 PM
kevin.egbert
Apr 20, 2016 08:25 AM
Jayb22
Apr 16, 2016 12:03 PM
