Cam Lobe and Rocker Arm Wear
Old Apr 28, 2016 | 10:50 AM
Timbo2500's Avatar
Default Cam Lobe and Rocker Arm Wear
I have been experiencing symptoms that appear to be similar to those of worn cam lobes and rocker arms. They appear to have uneven wear but I wanted to confirm with those that have more experience recognizing what that looks like. Please take a look at the attached pictures.
Old Apr 28, 2016 | 11:16 AM
Could be from excess heat,wrong oil used(usually these two go hand and hand) or a stopped/restricted oil galley,or could even be soft heat treatment related,same as what many early Polaris cams went through.
Old Apr 28, 2016 | 12:21 PM
Timbo2500's Avatar
Thanks OPT! Based on your experience does the cam and rocker show the kind of wear that would warrant replacement?
I got the ATV four months ago and it had a lot of water in the oil. Below is a pic of the first oil change. After five oil changes I think I finally have eliminated the water...
Old Apr 28, 2016 | 05:58 PM
Oil looks like a caramel glaze for dipping apples.. Yep water could have a lot to do with oil thinning and cam wear. Plus I'd kinda be worried about the piston and rings also.. My two cents is I'd be saving up for a rebuild in the future if it still runs good enough for now.
Old Apr 28, 2016 | 09:31 PM
Timbo2500's Avatar
OPT, thank you for the help! I recently put in a new piston, rings, and valves so I hope after the new cam and rocker arms it will be running like new.
polarisrider1203
17
Aug 9, 2016 02:56 PM
Feb 19, 2016 09:13 AM
ScoobyDFW
Jul 4, 2000 12:25 PM
Knottrider
Mar 17, 2000 08:53 PM
jlotz
Nov 11, 1999 09:54 PM
