Headlights
Old May 13, 2016 | 02:23 PM
bodatiouskid's Avatar
Question Headlights
On my 2002 Sportsman 700,when you switch to high beam only the 1 large headlight is on.Why?Why aren't all 3 lights on?
Is there a way to wire it up so all 3 burn on high beam?
Old May 13, 2016 | 02:25 PM
If they're still in business you can get the mod here..3 Headlight Mod Polaris ATV Lamps Kits Accessories Quad Parts Custom
Old May 13, 2016 | 05:25 PM
user493's Avatar
Moto Psycho
Montana Jack's also has a 3 headlight kit and it's cheaper than Quadovator. If you get the Montana Jack's kit I suggest you install it without the switch as I've had problems with the switch getting dirty and not working. MONTANA JACKS Polaris Headlamp Improvement Kit ? MontanaJacks Outpost
Old May 14, 2016 | 09:05 PM
WilliamBos's Avatar
I have a relay that I bought from a member, but I have a short fuse when it comes to wiring.
Old May 15, 2016 | 01:24 PM
user493's Avatar
Moto Psycho
I remember seeing a wiring diagram to install the relay and it was kind of complicated. To install one of these kits instead you just have to splice into 2 wires that are easy to find. The kit comes with 2 of those connectors where you put the wires in and squeeze it with a pair of pliers. IIRC the MJ's kit used to cost twice as much as the Quadovator kit. They must have lowered their price a lot, like from $20 or something like that. It comes with a switch that allows you to have just low beams, just the high beam, or all three. If you install it without the switch you can have low beams or all three but not the high beam by itself. If I still rode at night I'd definitely get one of the kits from MJ. I've had a few of them and the only problem I ever had was with the switch getting dirty. I would install it without the switch like I did the last time and avoid the problem completely.
50over
Apr 13, 2020 01:10 PM
AC-Greeny
May 8, 2016 04:03 PM
4EVR19
Apr 17, 2016 04:33 PM
Jayb22
Apr 16, 2016 12:03 PM
manxman
Apr 13, 2016 08:25 PM
