2013 Sportsman 90 no electric start
Old May 19, 2016 | 06:52 PM
holschuh11's Avatar
Default 2013 Sportsman 90 no electric start
I recently bought my baby sister a 2013 polaris sportsman 90. When i bought it there wasnt a battery in it. I bought a battery last friday but all it does is click.
Any ideas on what it could be?
Thanks for any help!
Old May 19, 2016 | 08:38 PM
At least it's getting power to the starter relay. You can check with a voltmeter or test light to see if the starter wire is getting power. If not,the the usual cause is a faulty relay. Item #13 on the parts break down.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse If the starter is getting power then it could be faulty.New Starter Polaris ATV Outlaw 90 and Sportsman 90 Replaces 0453478 and 0454952 | eBay http://www.ebay.com/itm/NEW-07-16-PO...5XMN~y&vxp=mtr
Old May 19, 2016 | 08:49 PM
holschuh11's Avatar
So if should I be able to jump the starter with a screw driver? And if it works then the relay is bad, correct?
Old May 20, 2016 | 07:54 AM
It's a relay(located under the seat) not a solenoid with two posts that you can jump across like other machines. Just use some jumper cables,ground neg to the frame and touch the starter hot wire if you wish to check it out that way. You still should be able to use a test light or meter first to see if power is getting to the starter motor from the relay when you push the start button and it clicks.
GoinCrzyWanaCom
Apr 13, 2016 10:16 AM
Mark Wilcox
Apr 4, 2016 02:48 PM
MNatv89
Mar 18, 2016 04:17 AM
thl1222
Feb 29, 2016 08:09 PM
TraxxasBeamer
Feb 27, 2016 08:47 PM
