Kawasaki 360 won't turn over /start
Old May 29, 2016 | 11:43 AM
Swiet's Avatar
Default Kawasaki 360 won't turn over /start
Hello, thank you for looking... I have a Kawasaki 360 that I was riding & turned off. When I went to restart it, the lights come on but it won't turn over. We have checked the battery, spark plugs & fuses & they are good. Seems as though its not getting a spark. It wont even start when trying to pull start it. Any ideas or suggestions would be greatly appreciated.
Old May 29, 2016 | 12:01 PM
Fasteratv's Avatar
Pull the spark plug, ground the plug to the engine head, turn engine over and check for a good blue spark. If you don't have spark, then you have an electrical issue.
Old May 30, 2016 | 09:12 AM
Swiet's Avatar
Default Electrical?
Thank you for the post. We aren't getting a spark. What would you suggest I check next?
Old May 30, 2016 | 01:47 PM
Fasteratv's Avatar
If you have no spark and tried this with a new plug, then you more than likely have a failed ignition componant. In order to effectively troubleshoot this, you will need a DVOM and the repair manual. The manuals are usually $5 for a download. Please see attached link. There are probably 8 possibilities in which can cause a no spark condition.
https://www.tradebit.com/G/manuals/184-kawasaki
Old Jun 1, 2016 | 04:41 PM
Swiet's Avatar
Default Won't turn over at all
Thank you for assisting me. It is truly appreciated. We turn the key on and get lights on the dash however when I push the button to start the engine, nothing happens. It doesn't even turn over so that is probably why there isnt a spark... Again, thank you for your replies and much needed assistance.
Old Jun 4, 2016 | 10:15 AM
Fasteratv's Avatar
Correct, if the engine won't rotate ( turn over with starter ) then you can't get spark. You will need to troubleshoot the starter system. Could be a faulty starter, solenoid, wiring, starter button on the handle bar. Are you sure the kill switch is in the run position?
grapejuice420
Mar 28, 2016 10:28 AM
razman_07
Mar 13, 2016 04:06 PM
Ross.B
Mar 6, 2016 10:01 PM
smitty2
Where to Ride
Mar 5, 2016 10:30 PM
