Polaris sportsman500 squeaky steering
Old Jun 22, 2016 | 09:51 AM
Brandon whitford's Avatar
Default Polaris sportsman500 squeaky steering
2007 sportsman 500 squeaks when I turn to the right only the right what's goin on haven't had a accident is the re a nipple to grease any help would be great
Old Jun 22, 2016 | 11:49 AM
1ArmBandit's Avatar
not sure on the 07...but id think there would be at least 1 steering bushing that needs to be greased...id just hit all the zerks with grease and see if it still squeaks
Old Jun 22, 2016 | 02:30 PM
More than likely the indentation for the grease fitting is still there on the frame. Drill it out and tap it along with making a hole in the bushings like the older models had,add the zerk fitting and you can keep the upper bushings greased.Stupid that they discontinued this little part.Item #2. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Jun 28, 2016 | 06:17 PM
Another question for ya will wheel bearings for a 2011 sportsman 500 fit a 2007
Old Jun 28, 2016 | 07:19 PM
Show to use different part number bearings for the front and also the rear. If you need to look up parts that can interchange use the Polaris Parts Catalog and on certain parts scan over to usage and click on it. Will show any models that use the same part numbers.http://parts.polarisind.com/Browse/Browse.asp
Kevin Vernon
May 31, 2016 09:48 AM
cstewart28
May 25, 2016 10:33 AM
ctxkiger
May 17, 2016 08:39 AM
cohunter
May 13, 2016 01:49 PM
RticKwad
Apr 25, 2016 09:17 PM
