Metal shaving on magnetic oil plug
Old Jun 29, 2016 | 09:02 PM
Vaxp1000's Avatar
Default Metal shaving on magnetic oil plug
Hey guys I'm new to the forum and I have a polaris sportsman xp 1000 and I was changing the transmission fluid and on the magnetic drain plug there was a 1" long half moon shaped super slim piece of metal on the plug and don't have any idea what it is and should I be alarmed? It's only got 12 hrs on it and runs great
Old Jun 29, 2016 | 09:27 PM
Metal shavings would be normal, a half moon solid piece of metal then no that's not normal.. Could be a part of a circlip or some other part in the gear case. With 12 hrs on the machine,I'd at least show this to the dealer so they have some sort of record on this.Whether it does any good or not depends on the dealer,what might happen to the machine later on,etc.
Old Jun 29, 2016 | 09:33 PM
Vaxp1000's Avatar
Yea I was thinking it wasn't normal and I sent them a pic and email today with no response so I guess I'll have to call them
Old Jun 29, 2016 | 09:36 PM
Vaxp1000's Avatar
Yea I didn't think it was normal and the oil looked good not burnt etc or even alot of small shavings on the plug just that slim piece
Old Jun 30, 2016 | 12:49 AM
switzomatic's Avatar
I agree with OPT. Definitely want to get it documented with the dealer.
Old Jun 30, 2016 | 09:39 AM
Vaxp1000's Avatar
Called the dealer this morning and he seems to think it's left over casting etc from manufactoring and said next fluid change if there still pieces like that they would wanna see it
Old Jun 30, 2016 | 09:56 AM
Casting pieces wouldn't be metallic... I've found extra bolts,nuts,etc in crates that were dropped while going down the assembly line,but these weren't anything to worry about. Could have been something accidentally dropped into the case during gear assembly and hopefully worked its way to the drain plug.Possibly any other piece of it can find its way there too. Keep us updated when you do the next oil change. Main thing the dealer knows about it...
Old Jun 30, 2016 | 10:10 AM
Vaxp1000's Avatar
I'll drop it again at 25 to 30 hrs and I'll keep yall updated
Old Jun 30, 2016 | 11:30 AM
DirtDevil101's Avatar
Yeah...ok...cases are aluminum and are non-ferrous (not magnetic)...I agree there could be some shavings, but they should be very, very small...good news is that you have a magnetic pick-up and it's doing it's job
Old Jun 30, 2016 | 11:40 AM
Vaxp1000's Avatar
Yea they will tell ya anything and I have broke it in like the manual says so if it breaks it's on the manufacturer so I'm just gonna ride it till it breaks or I change the fluid and see the same again
