Is my Fox 1.5 atv shock in need of a rebuild?
Old Jul 3, 2016 | 08:50 AM
DeFox500's Avatar
Default Is my Fox 1.5 atv shock in need of a rebuild?
The rear shock on my 02 Scrambler is a Fox 1.5 atv shock. The nut on the bottom is turned up as high as it goes, so it is set as stiff as possible. The rear end sags about 1/2"-1" from the weight of the quad. When I press down on the grab bar, not to hard, it feels very springy and bouncy. If I get the back end bouncing, it will continue for a few seconds after I stop. If I put about 40lbs on the seat, the rear end drops about 3-4". When my Dad who is about 200lbs sits on it, the springs look almost fully compressed. Before I washed the quad with a power washer, there was oil on the shaft. So do I need to rebuild my shock. I apologize for the length and I apologize if there is a similar thread already out there.
Old Jul 3, 2016 | 09:10 AM
Time to replace seals and oil and recharge the nitrogen. Most good motorcycle shops can do this and several online that you can send it to. Not anything that the average owner can do as special tools are needed.We rebuilt shocks mainly for our Ktms and a few Scramblers and it kept one of out techs pretty busy doing that. Most of the parts we used were from Race Tech.
Old Jul 3, 2016 | 09:14 AM
DeFox500's Avatar
Ok, thanks. There is a guy near me that can rebuild it. I just wanted to make sure it really did need a rebuild. Polaris tech, you are always a big help.
Old Jul 21, 2016 | 05:22 PM
DeFox500's Avatar
Time to replace seals and oil and recharge the nitrogen. Most good motorcycle shops can do this and several online that you can send it to. Not anything that the average owner can do as special tools are needed.We rebuilt shocks mainly for our Ktms and a few Scramblers and it kept one of out techs pretty busy doing that. Most of the parts we used were from Race Tech.How to Rebuild a Motorcycle Shock | Rocky Mountain ATV/MC - YouTube
Got the rear shock rebuilt. it is better, but still a bit soft. the guy did ask for my weight, height, and ride style, so im not sure if he revalved it for a person my size. with the adjustment nut on the bottom turned all the way up, the quad doesnt sag at all. with it halfway down, it sags about 1/8-1/4". so now my question is, do the scramblers just have a softer tail or did i get ripped off?
Old Jul 21, 2016 | 06:59 PM
As far as sag the manual shows the specs and I certainly can't remember what they are.If in doubt get the manual.2002 Polaris Scrambler 500 Service Manual PDF Download Or take the machine back to the guy that rebuilt it so he can set it up with you on it.
Old Jul 21, 2016 | 07:17 PM
DeFox500's Avatar
thanks for the link, ive been looking for a service manual for quite a while now. I guess I just like a stiffer tail, im used to driving my truck with a stiff af back end. as always, thanks for your help.
Kevin May
May 3, 2016 02:29 PM
Kevin May
May 3, 2016 11:02 AM
scottaruth
May 1, 2016 01:00 AM
Juan Diaz
Apr 28, 2016 05:31 PM
