What's wrong with this picture
Old Jul 6, 2016 | 08:41 PM
Yamahemi's Avatar
Default What's wrong with this picture
So two weeks ago I was out for a ride..
Let my nephew take the 500 for a burn and comes walking. Back says it just died
NO SPARK
so after checking the wires I discovered the pulse coil is nfg,
AB bolt had come loose and come around and taken out the pulse coil..
So replaces that turn key fires idles like shSpam wordSpam word Spam wordSpam word Spam wordSpam word Spam wordSpam word dies... hmm try again same thing..
Well after a few more attempts it just cranks and occasionally backfires.. plugs wet
We'll today I go to check my gapping and such good string spark double checked the timing and discovered this..
No Mater what I do nothing lines up
Cylinder is TDC cam is on point but the "T" is like 70 degrees out
Old Jul 6, 2016 | 09:59 PM
1ArmBandit's Avatar
sheer the key on the flywheel
Old Jul 6, 2016 | 11:33 PM
Yamahemi's Avatar
Nope triple checked that
Old Jul 7, 2016 | 12:30 AM
1ArmBandit's Avatar
sure you are at tdc? when you take the flywheel off when you think its tdc, what position is the key in?
Old Jul 7, 2016 | 12:41 AM
Yamahemi's Avatar
Pretty sure I stuck a 3/8 extension down the pug hole to feel for movement as for the keyway I'm. Not sure. I'll check after work tomorrow
Old Jul 7, 2016 | 12:47 AM
Yamahemi's Avatar
What position should it be at
Old Jul 7, 2016 | 07:54 AM
Have you removed the flywheel nut to see if the key has broken? Look at these pics from a member with the flywheel off and timing the cam up with the plated links. The flywheel key slot should be at 12 o'clock position.https://atvconnection.com/forums/pol...ml#post3305250
Old Jul 7, 2016 | 05:14 PM
Yamahemi's Avatar
Not sure how I missed it but it looks as though the fly wheel key is indeed broken... when you say 12 portion do you mean. To the bike or twelve to the top of the cylinder
Pic for fun
Old Jul 7, 2016 | 05:16 PM
Yamahemi's Avatar
Missed a step posting from my phone
Old Jul 7, 2016 | 06:53 PM
Definitely sheared and out of time. Hopefully the tapered shaft is ok. Any good hardware store should have this 5mm woodruff key.
