2002 Polaris Sportsman 600
Old Jul 18, 2016 | 01:21 PM
dfaircloth's Avatar
Default 2002 Polaris Sportsman 600
I have a Polaris Sportsman 600 and when I turn the ignition switch on to crank the motor, it has a slight delay before the motor begins to turn over to crank. As well as when I turn it off by the ignition switch, it has a slight delay before the motor turns off. Already replaced with a new ignition switch in it. Any ideas on what may be causing this?
Thanks!
Old Jul 18, 2016 | 02:09 PM
If you still have the Ducati ignition system,then probably the cdi/coil pack is beginning to act up. The replacement Kokusan kit #2202603 for the 600 gets rid of this system for a more reliable one. Here's the kit installed on a 700 which is basically the same thing.
thl1222
Feb 29, 2016 08:09 PM
TraxxasBeamer
Feb 27, 2016 08:47 PM
shore
Feb 27, 2016 11:12 AM
PolarisPower500
May 17, 2015 02:28 PM
patriot96
Oct 8, 2002 01:22 PM
