LED light bar wiring questions?
Old Jul 30, 2016 | 11:35 AM
WilliamBos's Avatar
Default LED light bar wiring questions?
Looking at getting a small LED light bar to mount on the front of my atv.
What I'd like to do is tie in to the high beam switch, either leaving the high bulb plugged in, or by unplugging the high beam.
I'd like to mount it at the bottom of the grill, tucked in. Would this cause a problem cooling?
Would the charging system be able to handle the high and LED, or be safe and unplug the high and use the plug for the LEED?
Old Jul 30, 2016 | 11:50 AM
LED's don't pull much power so I think you'd be okay power-wise. You'd have to wire in the harness after the switch as it needs the relay between power and the light bar. I'm not 100% sure that will work though as most of the relays I've seen have you wire from the battery to the switch. Not sure how much power goes to the stock high beam.
Old Jul 30, 2016 | 12:00 PM
WilliamBos's Avatar
I figure either unplug the high since it's useless anyway and use the plug, or just tap in before the high beam plug.
Old Jul 31, 2016 | 09:09 AM
TLC's Avatar
TLC
Would not mounting it higher on the grill rather then lower keep it out of the muddy water and crud better?
Old Jul 31, 2016 | 10:10 AM
WilliamBos's Avatar
Actually, higher up on the grill would be better for airflow too, eh?
But I never go in mud that deep, and water that deep is rare too!
Old Jul 31, 2016 | 11:23 AM
WilliamBos's Avatar
Just ordered these...
https://www.amazon.ca/dp/B01CI3LVLI/..._7yINxbPTD4BHE
Old Jul 31, 2016 | 02:19 PM
Should do the trick. I got a single 10" combo light with spot and flood lights. It's amazing how well it lights things up.
Old Jul 31, 2016 | 02:22 PM
Before
After
scottaruth
May 1, 2016 01:00 AM
gregk
1) Engine problems..
Apr 7, 2016 10:43 AM
Mark Wilcox
Apr 4, 2016 02:48 PM
Bowana
Mar 14, 2016 04:51 AM
Snky
Feb 8, 2016 07:13 AM
