2001 Polaris Scrambler 90 electrical issue
My 01 Scrambler will kick start and run just fine but I have no electrical power to tail light (no headlights on this one) or the starter. Battery is hot and good power to the on/off ignition switch. Where do I begin chasing down these electrical gremlins? Thanks for any advice.
7.5 amp glass fuse under the seat located close to the starter relay. If you don't see it,it may be tucked down below this area.Item#11 on the parts break down.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Plus here's a free pdf manual that can be used for all year models of the 50 and 90 2 stroke engines. Can help on future repairs and service.http://docslide.us/documents/2003-po...e-manual1.html Saw you have power at the switch..Sorry.. If you're pulling the left brake lever and starter doesn't work,then more than likely the little switch in the left control is faulty. It allows power to the starter relay and also is the brake light switch. No tail light on this model. Item#9.http://shop.cyclepartswarehouse.com/...01&fveh=285603 You can check with a test light or meter to see if power is getting to the relay. If not,then the switch.If it does have power,then probably the relay at fault. http://www.ebay.com/itm/Polaris-New-...FXH9hv&vxp=mtr
jmelton
Ask the Editor
Jan 7, 2016 06:58 PM
