Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
LT80 Boyensen power reed
Old Aug 4, 2016 | 05:32 PM
animalguy's Avatar
Default LT80 Boyensen power reed
Looking for a bit of help here. Rebuilding the top end of a new me to LT80. I have other posts in the 'kids quads' section.
I picked up a set of Boyensen power reeds, but I've never changed reeds before. The kit contains two reeds one with a large hole in it with a piece of reed valve extending into the center section. The other reed valve looks normal shape. Which way do I install these on the reed cage? I mean which one goes on top?
Thanks!
Old Aug 4, 2016 | 07:10 PM
410Customs's Avatar
Off Road Builderaholic
the one with the large opening goes on first, so it is against the metal reed cage
Then lay the solid (flapper) one on top
followed by the stock metal bit that only allows the flaps to open so far
Now the carb vacuum will pull the flap open and allow air to flow
I just installed these on my LT80 build I took some pictures, however they are not of huge help here
https://atvconnection.com/forums/suz...list-find.html
from left to right install the parts in that order, 2, 1, 3 if that makes sense
please ignore the camo crocs
Old Aug 4, 2016 | 07:20 PM
animalguy's Avatar
Thanks for the reply! This is just what I was looking for! The pics in your thread are awesome. That sure looks like a big project, but getting it running is sweet!
Old Aug 5, 2016 | 02:04 PM
DirtDevil101's Avatar
I have those same crocs bro!
Old Aug 6, 2016 | 06:44 AM
LT80's Avatar
LT80 Expert
"I just installed these on my LT80 build I took some pictures, however they are not of huge help here"
True, on a stock motor any increase in power is minimal at best.
Modify the motor for more air flow (rpm's) and they work better.
Old Aug 6, 2016 | 08:09 AM
410Customs's Avatar
copy that!
With any engine (air pump) we are only as good as our smallest bottleneck
Old Aug 8, 2016 | 11:30 AM
While not a huge HP increase, they tend to crisp'n up the throttle response (they open faster)...not that an 8yo will notice
RedRancher
Jan 12, 2026 04:06 PM
donw
Jun 20, 2016 03:19 PM
Jun 19, 2016 03:53 AM
Brawndo
Jun 14, 2016 03:39 AM
bergj1986
Jun 8, 2016 09:25 PM
