2014 Sportsman 570 Front Differential Leak
Old Aug 13, 2016 | 11:39 AM
instagramfinggaz's Avatar
Question 2014 Sportsman 570 Front Differential Leak
Hi everyone,
Recently Purchased a 2014 Sportsman 570 used via a private seller. Has about 975 Miles. The only problem I can find is a slight leak from the front differential. I have already purchased two seals online, just waiting for them to be delivered. The differential has a some play, I have attached a video, is this amount of play normal ? I am now wondering if I will also have to replace components inside of the actual differential...
Video- 2014 Polaris Sportsman 570 Differential Leak/Wobble - YouTube
"> 2014 Polaris Sportsman 570 Differential Leak/Wobble - YouTube
" type="application/x-shockwave-flash" width="425" height="350">
Old Aug 13, 2016 | 12:15 PM
That does look a little wobbly and loose just to be a couple years old. Could be just the out put bearing for that side,but as usual Polaris just sells it as a kit. If you do have to tear into it you can take the universal number on the bearing and get it at a bearing supply or possibly an auto supply. Item #3 is the kit used on both sides.
Attached Thumbnails 2014 Sportsman 570 Front Differential Leak-284414_transintl_1333067.gif
Old Aug 13, 2016 | 03:06 PM
WilliamBos's Avatar
Here is the link to a Polaris 570 service manual.
Let us know what you find once inside.
https://drive.google.com/file/d/0B_d...w?usp=drivesdk
Old Aug 14, 2016 | 03:15 PM
Yep I do believe that is going to be the problem. After researching it ive found a few rzr owners that had to replace that same piece. $270 part but the front end should be A+. Ill look into the gear box soon and let yall know. Cant wait to ride this bad boy
WilliamBos
Mar 9, 2016 03:55 PM
Meyerz400
Mar 9, 2016 02:54 PM
Mar 3, 2016 04:29 PM
Feb 23, 2016 06:11 AM
79hugger
Feb 7, 2016 08:16 PM
