1995 Polaris 400l 2 stroke waterpump
Old Aug 17, 2016 | 09:43 PM
Rodd's Avatar
Default 1995 Polaris 400l 2 stroke waterpump
I have a 400 xplorer the counterbalance shaft that the water pump seals on is in terrible shape and not sealing I've looked online and the used ones look risky and new is very pricey question is I'm sure I could mount an external pump and make it work just not sure on how many gpm the pump will need to push and if it is ok on the motor to leave the pump intact or if I should pull at least the impeller any help would be greatly appreciated
Old Aug 18, 2016 | 01:48 PM
Have your counter balancer rebuilt. Cheaper in the long run to do that. Look at the bottom of this listing for services offered.Polaris 350 400 Balance 3087042 Repair Service w P Bearing and Seals Included | eBay
Old Aug 18, 2016 | 08:47 PM
Rodd's Avatar
Thanks for the response I will listen to your advice just curious now do to the shaft being bent slightly oops! A Buddy has a 1996 scrambler 400 bottom end he would sell for parts looks the same but the fly wheel looks a little different then the one in my atv question being is that scrambler bottom end same as a 95 xplorer bottom end
Old Aug 19, 2016 | 06:25 AM
Mechanical parts are the same on all 400s. His stator, flywheel,cdi are different on his Scrambler. Your model has a pick up coil,his has an exciter coil. You can use his bottom end and use your stator and flywheel if you wish.
Old Aug 19, 2016 | 12:20 PM
Rodd's Avatar
Thanks
tsz711
Apr 6, 2016 04:39 PM
Trackerman
Mar 27, 2016 06:39 PM
QuadDude05
Jan 11, 2001 04:43 PM
exmxer
Dec 7, 2000 01:29 PM
