500 to 500 ho carb swap
Old Aug 18, 2016 | 10:16 AM
r1nsho's Avatar
Default 500 to 500 ho carb swap
Can I swap the stock 500 carb for an ho carb? Or is more complicated than that? I want to make sure the boots are the same size and anything else that might give me trouble. Oh and I do have the ho cam installed. Had a soft stocky. Thanks
Old Aug 18, 2016 | 11:28 AM
TLC's Avatar
TLC
You sure can it's a matter of getting the two boots on the carb to fit the larger 40mm vs your 34mm.
Many people made there own 500H.O before Polaris did in 2001. The installed the 500 scramblers high duration cam and it,s larger 40mm carb.
I know a guy who installed the hot cam but left the 34mm carb and he says the ATV runs great without jetting and he notice a power increase. I think the High duration cam was more important then the 6mm larger carb for the H.O's power increase.
Old Aug 18, 2016 | 01:36 PM
Keep your original BST34 carb. It's more reliable,less prone to leaking. Not that much to gain if you did swap to the BST40 and larger carb intake manifold.
Old Aug 18, 2016 | 04:49 PM
r1nsho's Avatar
Does anyone offer a decent jet kit for move power out of the stock carb?
Old Aug 18, 2016 | 05:06 PM
Yes Dyno jet is one,but again just my two cents you're paying mostly for the titanium jet needle. The original carb jet sizes in the kits are scraped off and are remarked using their own sizing system. If you're not doing anything else leave the carb stock and enjoy it as is.Only way to make any appreciable hp gains is adding an exhaust,better air flow after one of these carb kits. And if you really have money to burn try these guys.Aaen Performance - Polaris ATV Four Stroke - ATV Accessories
Bottl3andagun
Aug 29, 2016 09:34 PM
Leadfinger
Aug 18, 2016 02:15 PM
animalguy
Aug 10, 2016 12:23 PM
96honda
Aug 5, 2016 09:03 AM
Timbo2500
Aug 2, 2016 08:22 AM
