polaris 300 express 2 stroke
Old Sep 20, 2016 | 03:38 PM
Ricky Farmer's Avatar
Default polaris 300 express 2 stroke
i'm needing some help if your sitting on the 4-wheeler on the left side there is two vent line that connect to the frame where do they go also if you look to the right side there is some more of the same line with a t on them where do all of them go my daughters 4 wheelers all of them has dry rotted and i havn't a clue where the all go to replace with new line.
Old Sep 20, 2016 | 03:55 PM
Old Sep 20, 2016 | 04:02 PM
Look close,there should be an oil injector line from the pump to the left lower side of the carb. Right side of the carb has an atmospheric vent usually with a tee that hooks to a tube from the bottom of the fuel bowl. Usually these fall off over time. You can run a single vent line and tie it to the throttle or choke cable and let it terminate under the tank. Same for the fuel bowl drain/over flow tube. Just run a single line from the bowl nipple and extend it past the bash plate. Another vent can be from the gear case and it can be zip tied up out of the way also.
Polaris03
Sport Quads
Sep 26, 2016 03:56 AM
Bubblehead
Sep 19, 2016 07:25 PM
BruteForce1910
Sep 16, 2016 07:45 PM
