2004 Polaris 700 Twin sputtering at lower rpms
Old Sep 25, 2016 | 09:33 PM
Nathan Mertens's Avatar
Default 2004 Polaris 700 Twin sputtering at lower rpms
Hi all, having issues with my 700 twin carbureted model. It recently started missing at a lower rpm but fine at higher rpm... things I have done trying to fix this issue are as follows:
New plugs
New intake
Cleaned carb
airfilter is clean
two new rectifier's "Caltric brand"
Adjust throttle cable
New fuel "93"
After new rectifier it reved up smooth but then would die like I hit the kill switch. So sputtering stopped, but new issue of dying... So I ordered another rectifier thinking I had a bad one, nope same thing.. I am also confused, do I need the new ignition kit?? I feel like I dont since what I read is the ducati ignition is the coil and CDI are one and I have separate units on my bike.
Any help would be appreciated considering I am at my wits end with this and it is deer season....
Old Sep 26, 2016 | 08:49 AM
Not necessary to post in the regular forums and expert section on the same problem. Gets confusing for you and others having to jump back and forth.https://atvconnection.com/forums/pol...cate-post.html
WilliamBos
Aug 10, 2016 03:59 PM
Degoragon
Aug 3, 2016 09:03 AM
Timbo2500
Aug 2, 2016 08:22 AM
Ernie Sisson
1) Engine problems..
Jul 18, 2016 10:00 PM
Swariz
Jul 10, 2016 12:55 AM
