eastlake axle
Old Oct 8, 2016 | 06:34 AM
jeffk's Avatar
Default eastlake axle
after killing a rear cv I went searching and got 2 complete rear axles and 2 bearings for 159 shipped.I ordered them on Tuesday and they were sitting on my step Friday.The axles look to be of nice quality and fit perfectly.The bearings also look to be of good quality.They also come with a 1 year warranty which of course does not cover boots.Supposed to riding tommorrow and see if they perform.
Old Oct 8, 2016 | 07:18 AM
Good price. Saw them on ebay also. Hope they give you good service.
Old Oct 8, 2016 | 08:53 AM
jeffk's Avatar
I now have a spare stocker I took off as I decided to put both new ones in.
Old Oct 8, 2016 | 11:57 AM
jeffk's Avatar
I did notice today when washing her up that the boots are "scrunched" and dont recall them being that way b4 install.will this cause the boots to fail?
Old Oct 8, 2016 | 02:42 PM
On "scrunched boots" you may have to remove one clamp and wiggle the boot around so it can pop up correctly. Sometimes a little low pressure from an air gun can pop these out also. Hated when that happened. Boots need to be on correctly or the ribs can wear against another rib and tear.
Old Oct 8, 2016 | 06:48 PM
jeffk's Avatar
Thanks OPT! how does this happen they were not like that before install
Old Oct 8, 2016 | 06:59 PM
Clamps not fully tightened allowing the boot to turn or a little grease on the shaft or cv joint during factory assembly that can allow a boot to twist and scrunch up when you go to install it.
Old Oct 8, 2016 | 07:08 PM
jeffk's Avatar
Think I will try and twist them around a little with some pliers.Thanks again OPT
mrred85
3) General Discussions..
11
Feb 9, 2017 10:13 PM
FixMyToysZACH
FixMyToys
Nov 28, 2016 01:41 PM
Fireman16371
Oct 7, 2016 08:45 PM
jeffk
Oct 5, 2016 04:26 AM
230e
Sep 23, 2016 01:03 PM
