Charging issue
Old Oct 24, 2016 | 08:04 PM
200es's Avatar
Default Charging issue
Another issue with my 600. It's a 2004.5. Was out last night and the battery light started flashing and my headlights started going bright then dim. I got it home and checked with a multi meter and when running getting 18 volts. Was told it was the regulator I put a new one on and now it reads 12.6 doesn't change when reved up. It also will not run with battery disconnected. I checked the voltage on the 3 yellow wires from stator when running and none give more than 5 volts even been the battery reads 18. I'm kinda confused by this
Old Oct 25, 2016 | 09:03 AM
Weird transition year model on this 600.. Between Y1,Y2,Y3 should show around 18 vac +/- 20% at 1300 rpms. Possibly a stator problem if it's showing less,plus another problem is having the correct regulator. 2004 models had 3 regulators depending on the build date of the atv. The latest one(supposedly for the 2004.5 model) is expensive. The 2005 model 600s had the ecm module instead of a regulator. Item#23.2004 Polaris A04CH59AK SPORTSMAN 600 (A04CH59AK/AL/AN/AQ/AW) Electrical/Taillight | Cycle Parts Warehouse
Old Oct 25, 2016 | 09:12 AM
200es's Avatar
Default Voltage regulator
Shouldn't it still run if I disconnect the battery
Old Oct 25, 2016 | 09:27 AM
NO.. These were the first of the dci ignitions that had to have voltage to the cdi to run. Older models like the 325/330,425 and 500 had the old magneto triggered ignitions and could recoil start without a battery and stay running.
Old Oct 25, 2016 | 09:32 AM
200es's Avatar
With the old regulator when I started it would read 13 volts and creep up to 18 volts. I bought a new ricks motor sports one and now when I start it the voltage stay at 12.5 and doesn't move even when reved. Sounds like I got a bad regulator
Old Oct 25, 2016 | 09:39 AM
Could be a bad regulator,BUT find your build date. Your vin # to a dealer and and they can tell you. May take that expensive updated regulator.Even ricks shows three different stators and 2 different regulators.https://ricksmotorsportelectrics.com/results/
Old Oct 25, 2016 | 09:41 AM
200es's Avatar
I looked it up on ricks website and it says part#10-558 replaces 4010929
Old Oct 25, 2016 | 09:49 AM
Then Ricks should know.. Give em a call and tell them the problem you have. They should be able to help. I used their stators before and only had one where the pick up coil wires were reversed in the connector. They shipped a new one over night to replace it. Good company at least when I dealt with them.
Old Oct 27, 2016 | 01:40 PM
200es's Avatar
So I now have power coming from the regulator. I put the volt meter on the red wire off the voltage regulator and getting 8 volts at idle and 14 if I rev it up. But yet still doesn't show on the battery. Battery shows 12.7 motor off and 12.4 motor running and still flashes battery light
Old Oct 27, 2016 | 02:06 PM
Check all your connections on the regulator. If these are all ok,looks like you're going to be chasing a short or possibly a bad ground.
