Sport Quads Discussions on sport quads.
DS650X neutral and check engine light dont come on
Old Nov 20, 2016 | 09:23 PM
Kb43's Avatar
Default DS650X neutral and check engine light dont come on
I recently put my DS650X back together and when I turn the key it has no lights on the dash but the gages work. When I turn key off the check engine and neutral light flicker once..... also the clutch lever is pulled back and the bike is in neutral. The kill switch is set to the run position but it tries to start and there's no spark. Now there's a wire that runs on the side of the oil filter how sensitive is that to the heat cause my friend welded it in place with out me knowing and I'm wondering if that's the problem please help I'm out of ideas, it only back fired once and no start also were do you install the ignition coils cause there zip tied I don't no were it goes on the frame
