New guy needing help
Old Dec 20, 2016 | 10:56 PM
LarryHartline's Avatar
Larry Hartline
Default New guy needing help
Hello just joined,need help on a bc-y110 Chinese import . All I know now is that
I can get it to turn over , but that's it . I was wondering if anyone has a wiring diagram for one of these so I can see if there's a key for this thing.
For I don't see one anywhere,don't know much about theses, more into garden tractors , but it was good deal for the grand babies. And where can I get parts , like carb kit , maybe a coil . Any help would be great.
Old Dec 21, 2016 | 03:04 AM
Just googled it and ATV-BC-Y110 seem to be the only site that sells new ones, (bet their spares back up is poor).
Check for a spark by removing the plug, re-fit the lead and lay it on the head. If you have a spark, try cleaning the carb jets out with compressed air. The carb like the engine is probably a copy of the one fitted to millions of Honda small motorcycles. Your chances of a wiring diagram for a low volume Chinese import are slim.
Old Dec 21, 2016 | 06:45 PM
bengear90's Avatar
Your best bet probably is look for a good mechanic that can easily understand wiring diagram.
Old Dec 22, 2016 | 01:28 PM
DirtDevil101's Avatar
Did you check the basics:
1) Fuel getting to plug (wet plug)
2) Spark at plug (arc to frame & crank motor)
3) Compression - compression tester is best, but thumb over plug hole can be used as guestimate in a pinch - should pop thumb off
You didn't mention these so figured I'd ask...
Old Dec 22, 2016 | 08:25 PM
Larry Hartline
Week instead of getting a carb kit for the carb the man said it would be cheaper to get a new carb so I did ,put it on today and the 3rd time it turned over it started.😀
But that was with the jump box I have ,so I'm still not sure how you supposed to start it
Without a key , has a button on it but it doesn't do anything. Will try to get pic of what I need answers for soon . But hey it runs . Unlike the 2 pocket bikes I have . Thanks for the info so for . Will try to keep y'all posted.👍😎
Old Dec 27, 2016 | 06:20 PM
Larry Hartline
Here is some pics
Here's what i have
The bottom lever is choke ,what's the next thing above that's red,the next is lites, then on / off .
Top red switch on/off, black switch lites ,second red switch is what ? Black lever is choke
