Small oil leak when engine running
Old Jan 6, 2017 | 02:45 PM
Simon Miller's Avatar
Default Small oil leak when engine running
When the engine is running, I have a small oil leak. Trying to pinpoint source without tearing everything apart. This is from the left side, directly behind the water pump. Vey minor leak, but still something I need to fix. Small brown streak running from top to bottom.
Leak runs from top to bottom
Old Jan 6, 2017 | 02:53 PM
Check the clamps and hoses for breaks at the oil inlet and return lines. If that's good then the most other common area for leaks was on the copper washers on the metal oil lines behind the clutch backing plate.
Old Jan 6, 2017 | 03:28 PM
Not the oil inlet and return. I bet it's the washers on the metal oil lines. Looks like I'll have to take the clutch backing plate off to get access.
Thanks again.
Old Jan 7, 2017 | 11:43 AM
I'm pretty sure it's not the hoses, clamps or washers. Found another thread for a different machine with same problem. They have a better picture: http://www.polarisatvforums.com/forums/attachment.php?attachmentid=14568&d=1383423302
What should I look at next? 1999 Polaris Magnum 500
Old Jan 7, 2017 | 12:31 PM
Crank case breather line could even be the problem also that's located behind the oil inlet and return or the copper washers on the metal delivery lines. Either way best to remove the clutches and backing plate and you can find it.
Old Jan 7, 2017 | 12:39 PM
Funny you should say that. It looked like it was coming from the breather line, but I ruled that out because it's not supposed to have anything in it other than air. The one end by the spring lock was very dirty. I took it off and cleaned off the hose to look at it.
I'll take off the clutches and backing plate if needed, but of course that's not a minor project.
To rule out the breather line - what can I do? The hose looks like it's in good shape, it took a good tug to get off. And the spring was tight and seemed to be in place. Should I just replace that piece of hose and spring lock? Parts #12 and #13 on the air box diagram? And/or #42 and 43 on the Engine Mounting diagram.
http://pi54.com/corp/manuals/parts/9914925r01.pdf
Old Jan 7, 2017 | 12:50 PM
Take the backing plate off first.All you may have to do is cut a little off each hose end and refit the clamps if the hose isn't damaged elsewhere.I've done that several times. Hoses get worn and crack at the fittings mainly and leak. Plenty enough hose to cut some off each end. Don't over look the metal delivery lines and washers. Had plenty of leaks coming from this area also over the years.
