2001 spoetsman 500 HO radiator relocation
Old Jan 8, 2017 | 11:14 AM
Jsmfam11@gmail.com's Avatar
Default 2001 spoetsman 500 HO radiator relocation
Ok all thinking of moving the radiator up top on my sportsman 500. I am gonna buy new rad hose so I can hopefully bleed the system easier. Didn't know if anyone has did this yet.
Old Jan 9, 2017 | 01:46 AM
bengear90's Avatar
This is from another forum, kinda old thread but see if you can get some ideas:
01 Sportsman 500 Radiator Relocation - MudInMyBlood Forums
Old Jan 9, 2017 | 08:57 AM
Thanx alot gonna check it out and see.
Old Jan 9, 2017 | 08:23 PM
Just hoping I can get it to bleed easier than the last time I had to bleed it.
Old Jan 9, 2017 | 09:34 PM
These are the hardest to bleed Polaris models other than the Rangers with their long hose runs. Main reason is the the engine coolant return line goes back to the remote coolant filler neck instead of directly back to the radiator. Plus you have to make sure the radiator is clean front and back. Helps to jack up the machine,squeeze the hoses to help remove trapped air pockets and let the fan cycle on and off several times. This problem wasn't solved until the later 2004 or 2005 models when the return line ran straight back to the radiator. I know what a pain it is to bleed these models and the time it takes sometimes to do it right.
Old Jan 9, 2017 | 10:13 PM
I know it's a pain to bleed, you helped me a few months back. Was thinking of getting a radio with a cap on it rather than the filler that's on it.
Old Jan 12, 2017 | 06:11 PM
Ok on my machine which coolant line is the in and out of the radiator. When I relocator the rad I'm gonna put the in port on the top so the coolant flows down through.
Old Jan 13, 2017 | 08:23 AM
Facing the front of the machine: Left line goes to the water pump,right side is the return line that that runs to the top of the filler neck.
Old Jan 13, 2017 | 09:32 AM
Aren't they on the same side top and bottom
Old Jan 13, 2017 | 12:24 PM
Look at the diagram I posted earlier.
