Baja 90 Starting Issue
Old Jan 18, 2017 | 10:39 AM
TheUsername's Avatar
Default Baja 90 Starting Issue
Hello, I'm having an issue that I can't for the life of me solve. Last week, all of a sudden I no longer could start my quad, I turn the key and the Display, lights don't turn on, and starter won't engage. The only way I can start it is by jumping the solenoid via a screwdriver, but it is extremely annoying.
I've tried the following:
- Check battery charge
- Tried other battery (Yes a proper ATV battery)
- Press brakes (It has a safety start system when starter won't engage unless brakes are pressed)
- Had hey in on position
Not sure what to do, a friend told me I might have a blown fuse or short near the ignition? But not sure how to fix that.
Another weird thing I noticed it when I do not give throttle, the lights and display are lightless, but when pull the throttle the lights flicker in a weird way and get brighter, they dim again when I let go of throttle, this did NOT happen before when the power worked correctly.
Some additional info:
- Solenoid won't start the quad if the key is off or removed, does this mean the ignition is OK?
- Kill switch works
- Start button doesn't do anything, not even any sound.
Any ideas? I'm not very knowledgeable on ATV's.
Old Jan 19, 2017 | 03:01 AM
It would seem the main fuse has gone, you just have to find it. On the thick wire from battery to solenoid there will be a thinner one attached to one end of it. This goes to a fuse and then to the rectifier. Either the fuse has gone or this wire is broken.
