04 Sportsman 700 drive clutch
Old Jan 30, 2017 | 05:45 PM
vgilbertson's Avatar
Default 04 Sportsman 700 drive clutch
Have a 700 that would not disengage. found that the one way bearing was locked up and the sheave has a lot of cracks. Did get the bearing freed up but need to know what the options are so it doesn't happen again.
Thank you
Old Jan 31, 2017 | 04:53 AM
Hope you replaced the washers in front and behind the one way.If the clutch is still usable you can try to polish any rough feeling surface cracks down to keep from eating up belts.If they're really bad,probably time to replace the clutch. Here's a good post on one way bearing repairs along with clutch creeping that many have problems with. On a 500,but same style clutches.https://atvconnection.com/forums/pol...-creeping.html
Old Feb 5, 2017 | 09:08 AM
Thank you
I read someplace that and 800 clutch will fit the 700 and works better. Any thruth to that?
Old Feb 5, 2017 | 09:19 AM
Don't know if they work any better,but people have changed them out.
Old Feb 14, 2017 | 03:51 PM
I ended up purchasing a new clutch. Tracks center and operates like it is suppose to. Thanks for your help.
Old Feb 14, 2017 | 03:58 PM
Sometimes that's the best way to go. Glad you got it fixed.
