300 fourtrax axle keeps popping out of diff
Old Feb 4, 2017 | 01:19 PM
Chris.400's Avatar
Default 300 fourtrax axle keeps popping out of diff
I put a new front diff on my 300, I was told the axles were the same length, so i threw them in and went for a ride. When i got back I noticed the front right shaft was hanging out of the diff about half an inch, but it was still pulling. Why is it popping out? It happened once when I put it together so i pulled the little clip out and streched it a little so it would hold in, but it didnt work.
Old Feb 4, 2017 | 01:37 PM
Had the same thing happen on some after market axles for Polaris and when held side by side and collapsed in all the way,they were a tad shorter the oem axles.Not all did this,but some I installed for customers that brought in their own parts did.Just a thought.
Old Feb 4, 2017 | 01:57 PM
Chris.400's Avatar
The littler spacer on the top of the front diff, the one that is held in place with the bolt, which side does it go on? i may have it on the wrong side.
Old Feb 4, 2017 | 02:04 PM
That hopefully will be answered by some Honda guys on the forum. Just hang on..
Old Feb 5, 2017 | 09:25 PM
Chris.400's Avatar
I flipped the little spacer to the right side, if you are looking at the diff. Fixed my problem
Old Feb 5, 2017 | 09:46 PM
Glad you solved your problem.
