Arctic Cat 400 4x4 Output shaft
Old Feb 7, 2017 | 10:46 AM
santee's Avatar
Default Arctic Cat 400 4x4 Output shaft
The four wheel drive on my '07 Arctic Cat 400 stopped working. I noticed the boot is torn on the output shaft that leaves the front universal and enters the pinion housing allowing the output shaft to slip backwards out of the pinion housing. Can't figure out what holds the shaft in place unless the boot itself does this job. Any advice? Thanks
Old Feb 7, 2017 | 02:30 PM
hydrex's Avatar
Looks to me that there are 2 rubber bumpers, 1 on each end, then a spring on the front end that holds it in place. Download a parts manual from <mymowerparts.com> you can see how it all goes together. See if the bumpers are there and the spring. PN 0673-618 bumpers and PN 1402-618 for the spring.
Old Feb 7, 2017 | 04:26 PM
santee's Avatar
No spring found. This may have been an issue from previous owner. But that would certainly fix the issue. Thanks a million!
Old Feb 7, 2017 | 04:38 PM
santee's Avatar
2007 Arctic Cat 400 AUTOMATIC TRANSMISSION 4X4 FIS CAT GREEN (A2007ICH4BUSZ) FRONT DRIVE GEARCASE ASSEMBLY | CyclePartsNation Arctic Cat Parts Nation
I'm looking at a parts diagram now...don't see the spring or bumpers. We may be talking about different shafts.
Old Feb 7, 2017 | 04:42 PM
santee's Avatar
It would be part #5 in the diagram. Thanks
Old Feb 7, 2017 | 09:08 PM
hydrex's Avatar
Sorry, friggin dyslexia, was looking at the rear differential.
Old Feb 8, 2017 | 05:16 AM
santee's Avatar
No problem..thanks all the same.
