Bighorn 12 inch tires for 570 EPS (2016)
Old Feb 10, 2017 | 01:19 AM
RticKwad's Avatar
Runs Stealth!
Default Bighorn 12 inch tires for 570 EPS (2016)
Well getting around to installing these tires. Look at my picture side by side originals. I am really wondering if the two front will clear? Thoughts?
Thanks,
R'
Attached Thumbnails Bighorn 12 inch tires for 570 EPS (2016)-20170208_204030.jpg   Bighorn 12 inch tires for 570 EPS (2016)-20170208_204011.jpg
Old Feb 11, 2017 | 04:13 AM
switzomatic's Avatar
2" taller or less shouldn't be an issue. Worst case scenario would be having to add wheel spacers if they rub a little while turning. Can crank the shocks up for more clearance if you haven't done that already.
Old Feb 11, 2017 | 07:56 AM
RticKwad's Avatar
Runs Stealth!
No I havent raised the shocks. Is that something most do when they add the Bighorn 26" tires on? Ive never read that before.
Thx,
​​​​​​​R'
Old Feb 11, 2017 | 12:10 PM
greg74's Avatar
Should be fine, that's probably about your limit though without spacers. They are noticeably taller and wider.
