Outer Clutch Cover
Old Feb 13, 2017 | 01:23 AM
Chevrolet4x4s's Avatar
Default Outer Clutch Cover
I bought a 2001 325 Trail Boss that had lived a hard life as a parts quad but decided to fix it up instead. I need to replace the outer clutch cover since a previous owner cut the front half off of it. Will the aluminum cover from an 08 Sportsman 400 work on it?
Thanks,
Shane
Old Feb 13, 2017 | 08:26 AM
Here's the atvs used in your specific cover but you an actually go past these and even install the later larger bulbous plastic covers with some modification if you wish. As far as the metal cover on the 400,no. This setup mixes the Hawkeye with a Sportsman and everything's different. Cover wouldn't align with the holes.Even if it did it would be so noisy.
Usage : 5433542
Year Product Model Assembly
2003 ATV TRAIL BLAZER 400 CLUTCH COVER - A03BA38CA (4982568256C01)
2002 ATV SCRAMBLER 400 2X4 CLUTCH COVER - A02BA38CA (4969936993C01)
2002 ATV SCRAMBLER 400 4X4 CLUTCH COVER - A02BG38CA (4974677467A12)
2001 ATV TRAIL BOSS CLUTCH COVER - A01AA32AA (4963816381C001)
2001 ATV TRAIL BOSS 325 SE CLUTCH COVER - A01AA32AA (4963816381C001)
2001 ATV XPLORER CLUTCH COVER - A01AG25CA (4963866386C007)
2001 ATV TRAIL BLAZER CLUTCH COVER - A01BA25CA (4963666366C003)
2001 ATV SCRAMBLER 400 2X4 CLUTCH COVER - A01BA38CA (4968366836C001)
2001 ATV XPLORER 400 CLUTCH COVER - A01CG38CA (4963916391C005)
2000 ATV TRAIL BOSS CLUTCH COVER - A00AA32AB (4960076007C002)
2000 ATV XPLORER CLUTCH COVER - A00AG25CA (4954865486C009)
2000 ATV SCRAMBLER 2X4 CLUTCH COVER - A00BA38CA (4954835483C003)
2000 ATV SCRAMBLER 400 CLUTCH COVER - A00BG38CA (4954845484C007)
2000 ATV XPLORER 400 CLUTCH COVER - A00CG38CA (4954875487C009)
Old Feb 14, 2017 | 07:43 AM
Thank you I really appreciate it.
