2010 850 question
Old Feb 14, 2017 | 06:25 PM
Chris McClure's Avatar
Default 2010 850 question
My 850 2010 xp efi will run good then just sitting for a few minutes it wonts to shut off like it ran outta fuel then it will finally crank back anybody might know or have any ideas please thanks
Old Feb 15, 2017 | 08:12 AM
Couple things I'd do off hand. Change plugs.Other than a battery plugs are one of the most over looked parts.May be as simple as that. If that doesn't help then check fuel pressure. Should hold 39 psi +/- 2 psi. If fuel pressure checks out and still dies,could be a t-map connector or wiring harness problem that's plagued a lot of efi machines. This place a has heavy duty repair kits.https://otbpowersports.com/products/ This cheap service manual can help in narrowing down the problem also. 2010 Polaris Sportsman XP 850 Service Manual PDF Download
wherrax
Technical and How-To Articles
Feb 15, 2017 03:28 AM
shank0668
Jan 28, 2017 09:31 PM
inultus
Jan 19, 2017 11:54 AM
CraZySteve
Jul 27, 2012 07:27 PM
RticKwad
Dec 18, 2009 07:04 PM
