TPS Values MSU500 UTV
Old Feb 15, 2017 | 03:08 PM
wingingit2's Avatar
Default TPS Values MSU500 UTV
I have a Massimo MSU500 UTV and need to check the TPS readings. I think it is the same as a Hisun HS500 UTC. There are not any specs given in the Service manual I have, or owners manual. Any help on throttle body sensor values would be a big help.
It is running very rich. I can only get it started by pulling on the throttle body (clamp loose) and creating a gap at the mainfold on the engine side of the throttle body.
