flywheel problem?
Old Feb 23, 2017 | 07:33 AM
dumb-dumb's Avatar
5 Year Member
Angry flywheel problem?
Along the way of helping a friend with their polaris 90 I noticed the outside timing mark on the flywheel was not magnetic, not even a little. I had a damaged flywheel from a completely different atv & tested it's outside timing mark which also wasn't magnetic but whenever searching, people called it a magnet. It wasn't too expensive so i bought a new 1 & it was also not magnetic.
I know that the magnets can get weak over time but shouldn't it be at least somewhat magnetic to induce voltage in the pulse/trigger coil or is my thinking wrong? This is driving me crazy, any help would be greatly appreciated.
Old Feb 24, 2017 | 02:25 AM
Your thinking is wrong. It is the piece of steel passing close to the magnet in the trigger coil that induces a voltage in the coil. pass any piece of steel past the coil fast enough and you will get a spark.
Old Feb 24, 2017 | 09:00 AM
dumb-dumb's Avatar
5 Year Member
Thank you, I knew there had to be a magnetic field somewhere for it to work correctly, i was just looking for it in the wrong place (
