Alternative for the expensive Wilwood master cylinder.
Old Mar 8, 2017 | 08:15 AM
Chevrolet4x4s's Avatar
Default Alternative for the expensive Wilwood master cylinder.
Is there an alternative for the expensive Wilwood master cylinder on a 325 Trailboss? Or an adapter to switch the flared line to a banjo fitting.
thanks
Shane
Old Mar 8, 2017 | 08:23 AM
Plenty of Chinese master cylinders on ebay on ebay.Polaris Front Brake Master Cylinder For Polaris Trail Boss 325, 330, 2002 - 2013 | eBay
Old Mar 11, 2017 | 02:14 PM
Do you know if this will accept the flared type connector instead of the banjo fitting? My xplorer uses the banjo type fitting but the trailboss has a regular flared type connection.
Thanks,
Shane
Old Mar 11, 2017 | 02:24 PM
The one I listed would fit a 2002 model,last year on the 325 engine Trail Boss,but yes the 2000 and 2001 models had the flared screw in fitting like you mentioned. This one should work.FOR POLARIS FRONT LEFT BRAKE MASTER CYLINDER 2000-2001 TRAIL BOSS 325 NEW | eBay A lot cheaper than an oem master cylinder.You can chunk the switch that comes with it.
Old Mar 11, 2017 | 08:21 PM
Thanks again!
