Can someone help me diagnose a 4 wire CDI harness?
Old Mar 27, 2017 | 07:48 PM
MakDad's Avatar
Unhappy Can someone help me diagnose a 4 wire CDI harness?
Trying to diagnose a "no spark" problem, and want to test the plug that goes into the CDI. From what I've been able to research, it's a DC, 4 wire setup. I have a voltmeter and know how to use it a bit and can give you the readings if someone tells me what to test.
The quad is a 110cc, Loncin. I believe there is no 12 volts coming into the harness, but need specific instructions how to verify that.
Appreciate all the help.
Old Mar 28, 2017 | 09:31 AM
Zrock's Avatar
Super Quad Patrol
Personally iv always found it easier to just order a couple of new cdi's off ebay and swap them out. Iv never been able to get reliable readings testing s cdi
Old Mar 28, 2017 | 08:09 PM
MakDad's Avatar
I need to know how to test the current coming into the CDI in the 4 pin pigtail. Changing out random parts , guessing, usually leads nowhere, FAST
Old Mar 30, 2017 | 11:04 PM
bryanwheat's Avatar
Look up the Honda gy6 information and schematics. These are a clone of those engines. I agree with you, replacing parts to fix an issue is never a good idea. Properly diagnosing the problem before replacement is the only way.
Old Apr 1, 2017 | 06:11 AM
MakDad's Avatar
Great news. Since the yellow wire to geound didn't get me 12v DC, I ran a tester wire from the battery + post directly to CDI plug and bam.... I now have spark.
