Fan
Old Mar 30, 2017 | 11:03 AM
Atvassassin777's Avatar
Default Fan
Hey everyone, replaced my ecm yesterday, all is running smooth except i cant get fan to come on! Running hot, all oil and coolant levels are fine, radiator is clean, all wires look great! Any idea on a starting place?
Old Mar 30, 2017 | 11:20 AM
You can jump 12 volts to the fan motor itself and see if it works. If it doesn't Spal fans have replacements.https://webstore.spalusa.com/en-us/p...rcycleatv.aspx If fan works then recheck connections.
Old Mar 30, 2017 | 11:26 AM
Placing connections where to jump it? Pretty new at this atv stuff! 06 sportsman 450
Old Mar 30, 2017 | 11:31 AM
Just run separate ground and positive wire from a battery to the fan connector.
Old Mar 30, 2017 | 11:33 AM
Thank you OPT!!
Old Mar 30, 2017 | 02:39 PM
Tried the wiring trick with no luck! Guy at polaris told me about a sensor on bottom of radiator but no luck finding that either! Any other options??
Old Mar 30, 2017 | 04:23 PM
Look at your other post... easier to keep posts in one area rather than jumping around.Couldn't hook the fan up to a battery to see if it works or not or what?
