Axle Cross reference
Old Apr 5, 2017 | 09:26 AM
m2cyclone's Avatar
Default Axle Cross reference
Does anyone know what years and models all share the same rear axles.
The parts stores used to have the replacement chain on the parts. but I can't find any that support that now.
I know there were some rear hub/ axle upgrades just not sure of the years.
found a good deal on 2015 570 axles and other parts and would like to know if they would fit my 2000 sportsman. or if a hub upgrade would be needed.
front a-arms, front/rear springs should work on the old 500
I also have an 03 700 that most parts would fit too for spares.
thanks
Old Apr 5, 2017 | 12:15 PM
Not likely these will inter change.Only way to tell is to scroll over to usage on Polaris Parts on a particular part number and see what if any other models use the same part. Browse For example here's a rear drive shaft from a 2015 570 and what other models use the same one.
Usage : 1333275
Year Product Model Assembly
2017 ATV 570 SPORTSMAN 6X6 (R09) DRIVE TRAIN, MID DRIVE SHAFT - A17S6E57A1 (49ATVSHAFTDRIVERR1332935)
2017 ATV 570 SPORTSMAN 6X6 TRACTOR (R12) DRIVE TRAIN, MID DRIVE SHAFT - A17S6S57C1/CM (49ATVSHAFTDRIVERR1332935)
2017 ATV 450 FARMHAND HD 2x4 (R06) DRIVE TRAIN, REAR DRIVE SHAFT (FROM 8/29/16) - A17SAH50A5
2017 ATV SPORTSMAN TOURING 570 EFI/EPS (R09) DRIVE TRAIN, REAR DRIVE SHAFT (FROM 8/29/16) - A17SDA57A1/L2/E57A2
2017 ATV SPORTSMAN 450 HO (R07) DRIVE TRAIN, REAR DRIVE SHAFT (FROM 8/29/16) - A17SEA50A1/A5/SEE50A1/SEG50A4
2017 ATV SPORTSMAN 570 EFI (R11) DRIVE TRAIN, REAR DRIVE SHAFT (FROM 8/29/16) - A17SEA57A1/7/9/L7/L8/E57A1/7/9/F57A4
2017 ATV SPORTSMAN 570 EFI HD (R07) DRIVE TRAIN, REAR DRIVE SHAFT (FROM 8/29/16) - A17SEH57A7
2017 ATV SPORTSMAN 570 SP (R06) DRIVE TRAIN, REAR DRIVE SHAFT (FROM 8/29/16) - A17SHD57A9/AG/E57AS/E57AL
2017 ATV SPORTSMAN 570 SP TOURING (R07) DRIVE TRAIN, REAR DRIVE SHAFT (FROM 8/29/16) - A17SJE57AU (49ATVSHAFTDRIVERR1332935)
2017 ATV SPORTSMAN 570 EFI UTE (R09) DRIVE TRAIN, REAR DRIVE SHAFT (FROM 8/29/16) - A17SUH57N5 (49ATVSHAFTDRIVERR14SP500)
2017 ATV SPORTSMAN 570 EFI X2 EPS (R08) DRIVE TRAIN, REAR DRIVE SHAFT (FROM 8/29/16) - A17SWE57A1 (49ATVSHAFTDRIVERR1332935)
2017 ATV 570 SPORTSMAN 6X6 TRACTOR (R12) DRIVE TRAIN, REAR DRIVE SHAFT - A17S6S57C1/CM
2016 ATV 450 HO 2X4 MD (R08) DRIVE TRAIN, REAR DRIVE SHAFT - A16SAA57N1
2016 ATV SPORTSMAN TOURING 570 EFI/EPS (R10) DRIVE TRAIN, REAR DRIVE SHAFT - A16SDA57A1/L2/E57A2
2016 ATV SPORTSMAN TOURING 570 EFI EPS MD (R10) DRIVE TRAIN, REAR DRIVE SHAFT - A16SDA57N2/E57N2 (49ATVSHAFTDRIVERR14SP500)
2016 ATV SPORTSMAN TOURING QUAD 570 EPS (R10) DRIVE TRAIN, REAR DRIVE SHAFT - A16SDC57C2 (49ATVSHAFTDRIVERR14SP500)
2016 ATV SPORTSMAN TOURING TRACTOR 570 EFI EPS (R09) DRIVE TRAIN, REAR DRIVE SHAFT - A16SDS57C2 (49ATVSHAFTDRIVERR14SP500)
2016 ATV SPORTSMAN 450 HO (R10) DRIVE TRAIN, REAR DRIVE SHAFT - A16SEA45A1/A5/SEE45A1
2016 ATV SPORTSMAN 570 EFI (R12) DRIVE TRAIN, REAR DRIVE SHAFT - A16SEA57A1/3/7/8/9/L3/L7/L8/E57A1/3/5/7/9/D57A2
2016 ATV SPORTSMAN 570/450 EFI MD (R08) DRIVE TRAIN, REAR DRIVE SHAFT - A16SEA57N1/N7/E57N1/E57N2/BA57N1
2016 ATV SPORTSMAN 570/450 EPS QUAD (R12) DRIVE TRAIN, REAR DRIVE SHAFT - A16SEB57C1/C2/SEC57C1/C2/CL/SBB57C1 (49ATVSHAFTDRIVERR14SP500)
2016 ATV SPORTSMAN 570 EFI HD (R11) DRIVE TRAIN, REAR DRIVE SHAFT - A16SEH57A7
2016 ATV SPORTSMAN 570/450 EPS ZUG (R09) DRIVE TRAIN, REAR DRIVE SHAFT - A16SES57F1/F2/SBT57F1
2016 ATV SPORTSMAN 570/450 TRACTOR (R10) DRIVE TRAIN, REAR DRIVE SHAFT - A16SET57C1/C7/SES57C1/C2/SBT57C1
2016 ATV SPORTSMAN 570 SP EPS, QUAD (R10) DRIVE TRAIN, REAR DRIVE SHAFT - A16SHC57CM (49ATVSHAFTDRIVERR14SP500)
2016 ATV SPORTSMAN 570 SP (R10) DRIVE TRAIN, REAR DRIVE SHAFT - A16SHD57A9/AR/E57AS/AM (49ATVSHAFTDRIVERR1332935)
2016 ATV SPORTSMAN 570 SP MD (R09) DRIVE TRAIN, REAR DRIVE SHAFT - A16SHE57NM (49ATVSHAFTDRIVERR14SP500)
2016 ATV SPORTSMAN 570 SP EPS, TRACTOR (R09) DRIVE TRAIN, REAR DRIVE SHAFT - A16SHS57CM (49ATVSHAFTDRIVERR14SP500)
2016 ATV SPORTSMAN 570 SP TOURING (R08) DRIVE TRAIN, REAR DRIVE SHAFT - A16SJE57AB (49ATVSHAFTDRIVERR1332935)
2016 ATV SPORTSMAN 570 EPS UTE QUAD (R11) DRIVE TRAIN, REAR DRIVE SHAFT - A16SUC57C1 (49ATVSHAFTDRIVERR14SP500)
2016 ATV SPORTSMAN 570 EFI UTE MD (R10) DRIVE TRAIN, REAR DRIVE SHAFT - A16SUE57F1 (49ATVSHAFTDRIVERR14SP500)
2016 ATV SPORTSMAN 570 EFI UTE HD (R11) DRIVE TRAIN, REAR DRIVE SHAFT - A16SUH57N6 (49ATVSHAFTDRIVERR14SP500)
2016 ATV SPORTSMAN 570 EFI UTE TRACTOR (R09) DRIVE TRAIN, REAR DRIVE SHAFT - A16SUS57C1 (49ATVSHAFTDRIVERR14SP500)
2016 ATV SPORTSMAN 570 EFI X2 EPS (R12) DRIVE TRAIN, REAR DRIVE SHAFT - A16SWE57A1/A7 (49ATVSHAFTDRIVERR1332935)
2015 ATV HAWKEYE 325 2X4 DRIVE TRAIN, REAR DRIVE SHAFT - A15SAA32EH (49ATVSHAFTDRIVERR1333275)
2015 ATV SPORTSMAN TOURING 570 EFI/EPS DRIVE TRAIN, REAR DRIVE SHAFT - A15SDA57AA/LJ/E57AJ
2015 ATV SPORTSMAN 570 EFI TOURING EU DRIVE TRAIN, REAR DRIVE SHAFT - A15SDA57FH (49ATVSHAFTDRIVERR14SP500)
2015 ATV SPORTSMAN TOURING 570 EFI MD DRIVE TRAIN, REAR DRIVE SHAFT - A15SDA57HH/HA (49ATVSHAFTDRIVERR14SP500)
2015 ATV SPORTSMAN ETX EFI DRIVE TRAIN, REAR DRIVE SHAFT - A15SEA32AA/AH (49ATVSHAFTDRIVERR1332935)
2015 ATV SPORTSMAN ETX EFI MD DRIVE TRAIN, REAR DRIVE SHAFT - A15SEA32HA (49ATVSHAFTDRIVERR14SP500)
2015 ATV SPORTSMAN 570 EFI DRIVE TRAIN, REAR DRIVE SHAFT - A15SEA57AA/AC/AD/LD (49ATVSHAFTDRIVERR1332935)
2015 ATV SPORTSMAN 570 EFI MD DRIVE TRAIN, REAR DRIVE SHAFT - A15SEA57HA (49ATVSHAFTDRIVERR14SP500)
2015 ATV SPORTSMAN 570 EFI EPS FOREST QUAD DRIVE TRAIN, REAR DRIVE SHAFT - A15SEB57CA/CJ/SEC57CJ/CA (49ATVSHAFTDRIVERR14SP500)
2015 ATV SPORTSMAN 570 EFI EPS DRIVE TRAIN, REAR DRIVE SHAFT - A15SEE57AA/AC/AJ (49ATVSHAFTDRIVERR1332935)
2015 ATV SPORTSMAN 570 EFI EPS MD DRIVE TRAIN, REAR DRIVE SHAFT - A15SEE57HJ/HA (49ATVSHAFTDRIVERR14SP500)
2015 ATV SPORTSMAN 570 HD DRIVE TRAIN, REAR DRIVE SHAFT - A15SEH57AD (49ATVSHAFTDRIVERR1332935)
2015 ATV 570 EFI/EPS FOREST TRACTOR DRIVE TRAIN, REAR DRIVE SHAFT - A15SET57CA/S57CJ/CA (49ATVSHAFTDRIVERR14SP500)
2015 ATV SPORTSMAN 570 SP EPS, QUAD DRIVE TRAIN, REAR DRIVE SHAFT - A15SHC57CS (49ATVSHAFTDRIVERR14SP500)
2015 ATV SPORTSMAN 570 SP DRIVE TRAIN, REAR DRIVE SHAFT - A15SHD57AC/E57AS/AM/L57AK (49ATVSHAFTDRIVERR1332935)
2015 ATV SPORTSMAN 570 SP MD DRIVE TRAIN, REAR DRIVE SHAFT - A15SHE57HS (49ATVSHAFTDRIVERR14SP500)
Old Apr 5, 2017 | 12:34 PM
user493's Avatar
Moto Psycho
It's a different body and chassis. I'd be surprised if anything more than nuts and bolts would be the same between a 2000 500 and a 2015 570. There were even some differences between the 2000 and 2001 Sportsman 500s. If there are differences in one model in one year there have to be a lot of changes between 2 completely different models in 15 years.
