Big Bear High Low Reverse lever Cable
Old Apr 14, 2017 | 01:33 PM
lciummo's Avatar
Default Big Bear High Low Reverse lever Cable
Hi
I had to replace a missing H/L/reverse level cable on an 1988 Big Bear 350. It's the lever on the front right fender. The new cables is in, but i can't adjust it so that it moves the lever on the back of the engine - it just doesn't have enough "throw" on the cable. I suspect the level is screwed up or the way it's attached to the cable and bracket.
Does anyone have a picture to post or take a look at mine. Take a look at mine it can't be right the way it is because the handle moves it just back and forth a bit.
Thanks
Larry
