bayou 300 propellor shaft bearing removal?
Old Apr 15, 2017 | 03:35 PM
BigWheelWade's Avatar
Default bayou 300 propellor shaft bearing removal?
Hey all, took my rear propellor shaft out along with the flanged housing that holds it to the rear differential. I took the retainer clip off so I could pull off the bearing/shaft from the housing but the bearing wont come out of the housing? What is the trick to getting this out? Thanks
Old Apr 16, 2017 | 12:58 PM
Pretty chatty group here! I had to press the bearing out by using a press from the other end pressing against the shaft. Got it mostly back together now. Might get a chance to try it later
