2001 Fourtrax/TRX 350 FM clutch question
Old Apr 16, 2017 | 05:54 PM
Blue Igloo's Avatar
Question 2001 Fourtrax/TRX 350 FM clutch question
Shifting my manual clutch pedal seems to be getting stiffer and harder to shift. It still has the factory setting. Should I be decreasing or increasing the clutch adjustment to make shifting easier or is it something else?
Thanks
Ron
Old Apr 16, 2017 | 08:54 PM
papa hogg scoot's Avatar
Loved
Community Favorite
If hard to shift lever to change gear I would incease freeplay on clutch adjustment,Have to change the oil to an different oil?
Old Apr 16, 2017 | 08:55 PM
Loved
Community Favorite
Welcome aboard.
Old Apr 17, 2017 | 11:14 AM
Blue Igloo's Avatar
Thumbs up
Thanks PHS!
I will try increasing the adjustment. BTW, I did change the gear oil beforehand to semi-synthetic 80/90 since I run my quad in the winter too.
Blue Igloo
Old Apr 17, 2017 | 04:06 PM
Blue Igloo's Avatar
I did already change the motor oil to 10/40 for the summer. I'm not sure I know what you mean by "increase freeplay on clutch adjustment". Do I tighten or loosen the clutch adjustment screw?
Thanks
Blue Igloo
Old Apr 17, 2017 | 07:39 PM
Loved
Community Favorite
It has increase stampped on front engine case cover beside the clutch adjustment screw should be .I was just answering your question in your post you asked should i decrease or increase freeplay...Increase would be the correct way to adjust if gear lever is hard to change gears or hard to move into gear change.
Old Apr 17, 2017 | 07:42 PM
Loved
Community Favorite
Did you use an oil made for atv wet clutch? Gear oil doesnt effect gear lever.but 80/90 is correct there
Old Apr 17, 2017 | 07:53 PM
Loved
Community Favorite
Old Apr 17, 2017 | 07:55 PM
Loved
Community Favorite
Watch this short video..skip the value adjustment unless you need to watch that one also...Clutch CANBE done with engine still in atv overlook that part.I just foundt this video an thought it may help you understand better..GOOD LUCK Were here if you have any questions.
Old Apr 17, 2017 | 08:03 PM
Loved
Community Favorite
If you get the clutch adjustment correct when you put you toe/foot under shifting lever an lift up with foot an leave there and then rev engine up and atv shouldnt move until you release foot...Think of it this way like an handlebar clutch on manual shift motorcycle foot and hand does the same thing,pull in clutch on motorcycle clutch stops pulling same has foot shifting lift foot clutch disenage.
