question
Old Apr 21, 2017 | 01:52 AM
4-wheeler's Avatar
Default question
what will make the 04 polaris 500 ATP 4X4 just quit pulling when you are riding it but when you put it in 4wd it will move so what could be the problem with it some people have said that ot could be the rear end and then some other people say's it could be the tran's out of it so what do you think it could be
Old Apr 21, 2017 | 03:35 AM
Rear prop shaft coupler splines that go to the rear differential have stripped out from lack of grease,water and corrosion.Common problem on the Atp and Magnum because of the hard to see grease zerk through the holes of the box frame. Usually the diff spines are ok as it's harder steel. Item #15 in the parts break down.
jjgulley
Apr 27, 2017 08:24 AM
BROCK2969
Nov 15, 2016 10:45 AM
Darwin heying
Oct 24, 2016 03:05 PM
eyeowa
Oct 24, 2016 12:02 PM
atom0s
Jul 21, 2016 11:44 AM
