1998 Yamaha Big bear 350 4x4 no spark
Old Apr 27, 2017 | 03:04 PM
Md7714's Avatar
Default 1998 Yamaha Big bear 350 4x4 no spark
A little history..this quad was running about 8 months ago. Inside the housing where the starter is, the housing broke holding the gears connecting starter to the crankshaft so now all I can use is pull start. After everything broke, I changed oil and made sure no metal in it but it wouldnt start. I got busy and let it sit for 8 month. I am trying to get it running now with pull start. I do not have any spark. I am not showing any power to ignition coil. Thanks
Old May 25, 2017 | 03:34 PM
lciummo's Avatar
You have the wiring diagram or the pdf manual - very helpful for figuring out what's bad. I can send if you need it.
