Jetmoto Oil Capacity
Old May 2, 2017 | 03:10 PM
RedSoxWest's Avatar
Default Jetmoto Oil Capacity
Just picked up a 2007 250cc Jetmoto with no manual. Can anyone tell me the correct oil capacity so I can change it. Can't see through the side oil window. Thank you.
Old May 2, 2017 | 03:28 PM
hugemoth's Avatar
If it's the vertical air cooled manual transmission engine it should hold about 1.2 quarts. Liquid cooled would be the same. Be sure to use oil that is compatible with a wet clutch.
Old May 3, 2017 | 01:35 PM
RedSoxWest's Avatar
Thank you. Much appreciated.
Old May 9, 2017 | 12:59 PM
ripcuda's Avatar
Rotella T 15w-40 diesel oil is great oil for engines with wet clutches. Heavy duty, affordable and none of the automobile oil additives in it. Very recommended.
Cheers!
