replacement carb for 1995 kawasaki bayou 300 c7 4x4
Old May 3, 2017 | 01:45 PM
copterdoctor's Avatar
Default replacement carb for 1995 kawasaki bayou 300 c7 4x4
my choke has a pin and a spring that screws into the housing and the carb that was sent to me has a different provision ?
Old May 3, 2017 | 03:59 PM
Most of the replacement carbs look like this one that has the rubber boot and fitting on the carb that you can use your old choke cable with and spring and plunger if the new one doesn't have it. From what I see your old carbs choke is on the side. Should be able to work?
Attached Thumbnails replacement carb for 1995 kawasaki bayou 300 c7 4x4-s-l300.jpg   replacement carb for 1995 kawasaki bayou 300 c7 4x4-index.png
Bvmodica
Apr 19, 2017 09:45 AM
randleton
Mar 24, 2017 06:42 PM
STCxSeabass
Utility ATVs
Mar 20, 2017 06:57 PM
momoboy
Feb 24, 2017 08:12 AM
