CDI Problems
Old May 27, 2017 | 09:32 PM
Randy Booth's Avatar
Default CDI Problems
I recently bought my son a Eton Viper Mini 50. The lady I bought it from said that it didn't have spark. Her nephew looked at it and said that it needed a new cdi box, so she ordered one. It is an aftermarket. Once I brought it home, the new cdi box was just partially hooked up. There are 5 wires coming from the cdi box. The 2 that are hooked up is a orange wire and a black wire. These are the only two that have a connector and they are hooked into the same connector that runs to the ignition coil. The ignition coil is new as well. The other three wires are uncooked. There is a red w/black stripe, red w/white stripe and one black w/white stripe. The unkooked wires above the cdi box does not match these colors and I have no clue which one goes to which. There is also two wires that run to the tether kill switch, and I'm not sure if these are even right. I have fooled around with it some and was able to get a very weak spark but then it went away. I don't know if I hooked something up wrong or what. Any insight would be appreciated. I have included pics as a visual. Thanks in advance. These are the 5 wires coming from the cdi box
These are the five wires above the cdi box
These are the two wires that run to the tether kill switch
