Polaris Trail Boss 330 Brakes
Old Jun 5, 2017 | 04:54 AM
Frank_Akpik's Avatar
Default Polaris Trail Boss 330 Brakes
Hey I was wondering if anyone knew how to fix this, ok so here's what happened... I was going to go ride my four wheeler, we were about to leave the drive way when the brakes weren't working. So we put by the house and checked the brakes. The Front Brake thing was out of fluid so we went and put more in. But they still weren't working, and then for some reason the rear brakes aren't working now. When we were testing the rear brakes we also put more fluid into, still wasn't working. Then I noticed that the brake caliper was leaking the Brake Fluid. Can someone please tell me why it was leaking the fluid? And why the front brakes still aren't working?
Old Jun 5, 2017 | 08:45 AM
Either leaking around the caliper piston seals or the two small o-rings that go between the caliper halves are leaking.For Polaris Trail Boss TrailBlazer Scrambler Brake Caliper Seal Rebuild Kit Rear | eBay This needs to be repaired and then bleed the brake system.Easier to bleed with a mity vac than to try to manually bleed each caliper bleed valve.
