My yamhaha warrior 350 starting problem NEED HELP
Old Jun 13, 2017 | 04:25 PM
Warriorrrrrr's Avatar
Default My yamhaha warrior 350 starting problem NEED HELP
I have a 2001 warrior 350 and it just clicks when I try to start it I put a brand new cylinoid in it and it still clicks(sounds comeing from the cylinoid) couldnit be the starter or the coil¿
Old Jul 4, 2019 | 10:51 AM
UnpleasantSoul's Avatar
Does it start if you jump it or push start it? Im having a power issue. I het no power unless i jump start it, but if its stalled or dies its back to no power.
Check and charge your battery
Old Jul 4, 2019 | 03:03 PM
Kymco 450i's Avatar
Clicking normally means low voltage, to low to activate the solinoid. Even if battery shows a decent charge it could have an internal short. That is why a load test is needed to check for internal short or dead cells. Also check all connections, a bad or corroded connection can cause the same issues.
Old Jul 13, 2019 | 08:29 AM
Zrock's Avatar
Super Quad Patrol
you do realize you answered a 2 year old post where the person only had a few posts.. Pretty sure they are not going to answer.
