2000 Xpedition 425 electrical problems
While I was riding shut off and lost Speedo , lights, fan, Awd , reverse override and electric start quit working . Started with the pull start and was able to get it back to the truck. Took the Speedo in and had it tested and hab a bad transistor in it . Plugged it back in and still the same thing . When running it still charging and at idle getting around 5 volts to the Speedo. Any thoughts on where to look next or what to do .
Check the main circuit breaker in the plastic pouch located up from the battery. Should have voltage in and out on the red wire. You can slice the pouch open and if the circuit breaker is corroded you can get one at any auto supply for a few bucks.
Did check and have current running thru it .
All grounds from back are good and clean . I will have to pull the wire harness and chase wires .
