Output shaft fix
Old Jul 30, 2017 | 08:32 AM
Matt Behnke's Avatar
Default Output shaft fix
Hi,
I have a 2001 Yamaha warrior 350. Yesterday when I was riding, the nut that holds the front sprocket came off, and after closer inspection I saw that the threads on the output shaft that holds the nut were stripped. They were stripped down to nothing. So I am wondering if I can just re tap this shaft for a slightly smaller nut, and call that good to hold the sprocket? I would much rather do this than to have to replace the entire shaft and take apart the engine. If I can do this, is there any specific thread type (coarse or fine, right hand, left hand, etc.) I should use? Or will this not work and I am best off replacing the whole shaft? Thanks for the help Here's the specific part. You can't see too well the stripped threads, that's because we did a quick temporary fix with some snug washers.
Matt Behnke
Sport Quads
Jul 30, 2017 11:36 AM
Matt Behnke
Ask the Editor
Jul 30, 2017 08:39 AM
ENRKyle20
CAN-AM (BRP) Ask an Expert!
Jul 9, 2012 12:37 PM
aklester
Jul 17, 2005 05:05 AM
YamaHonda
Feb 17, 2000 10:27 AM
