EBS Clutch question.
Old Jul 31, 2017 | 11:03 AM
WilliamBos's Avatar
Default EBS Clutch question.
04.5 500HO with EBS - can the one way bearing be changed or will a new primary be required?
What about secondary - fully rebuildable??
Old Jul 31, 2017 | 12:06 PM
You can replace the one way separately along with the two washers. If guide buttons are worn replace them also since they have to be removed to get to the one way. And since you'd be that far into it,I'd replace the two bushings.In other words rebuild the drive clutch. Main thing that wears on the secondary is the three rollers but check the helix for excessive wear.
Old Jul 31, 2017 | 01:12 PM
WilliamBos's Avatar
Thanks OPT. I will pass the info along.
